Sony DAV-S550 auto decode help
Discussion in 'Home Cinema Buying & Building' started by Tarks, Aug 25, 2006.
  1. Tarks
    Tarks
    Recently bought my first house and splashed out on a Samsung LE32R74 and Sky +. Not got the money more a new sound system so stuck to my trust DAV-S550, but the auto decode doesn't work. I've plugged the sky+ into the all in ove via RCA (I think 2 pin to 2 pin). But I have to manually select surroundsound or 2 channel dependent on prog. If I leave on surroundsound the rear speakers just give out some squeeky noises. Is there any way to get it to auto decode and switch manually?
    Thanks,
    Chris.
  2. Tarks
    Tarks
    Bought an Optical cable and now switches automatically :)
