Sony DAV S500 question
Discussion in 'AV Receivers & Amplifiers' started by bobble, Jul 8, 2002.
Tags:
  1. bobble
    bobble
    Jul 8, 2002
    159
    2
    +6
    To anyone that has DAVS500, you can obviously plug in your Sky Digital and VCR audio into the inputs of the DAVS500, can the sound be then set to output in PRO-Logic,
    Thanks in advance,
  2. SonyDVDMaster
    SonyDVDMaster
    yes, the DAV-S500 or any pro-logic/digital processor only needs a stereo signal and then it puts the sound into pro-logic
  3. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,905
    That is not strictly true as it needs to receive a pro logic signal not a stereo one.
    Not all television programmes are encoded in Pro Logic.
  4. hermand
    hermand
    Mar 8, 2002
    43
    London
    ...but if the signal is not pro-logic encoded, i.e. vanilla stereo, your processor will still attempt to decode it in a pro-logic fashion - e.g. out of phase sounds sent to the rears etc.
    Herman
