sony dav-s400 help needed!
Discussion in 'Home Cinema Buying & Building' started by ukgeordieman, Jun 5, 2005.
  1. ukgeordieman
    ukgeordieman
    hi my sony system has worked fine for about a year then suddenly i cant get sound from it when i try to change sound field i just get stuck on headphone channels when theres none connected no matter what i do i can get away from the headphone setting please some 1 help?
  2. himdman
    himdman
    This is caused by bad solderings on the amplifierboard.
    Resolder the connector for the wire to the headphone board. Also check the solderings for the coils and power capacitor.
