Sony DAV-S300
Discussion in 'Home Cinema Buying & Building' started by sparkylogan, Oct 27, 2000.
  1. sparkylogan
    sparkylogan
    I'm thinking on getting one of these units and would like to hear from anyone who already has one. Any comments would be appreciated!
  2. Guest
    I got one for the old man....he's very happy with it but after I got it for him, he decided he had a need to play videCD's in it (which it won't do!) so I think he now has his eye on the new Pioneer combo unit.
    Cheers,
    Tom...
  3. D J Fryer
    D J Fryer
    Jul 14, 2000
    819
    28
    High Wycombe, Bucks
    +26
    I have listened to all three out there - the Sony, Panasonic and Pioneer NS-DV55. I bought the Pioneer because of the following
    It sounds better
    It looks better
    It is better equipped (DTS DD RDS Tuner, CD, VCD, CD-R, CD-RW)
    Picture quality is good - I would say that on a par with a Pioneer £275-300 separate player
    It is well built (the Panny is terrible)
    It plays music better than the others (on CD)
    A few reasons - obviously it is a few bob more expensive than the others but I picked mine up - fully modded - at www.leconcepts.com for £609.99 incl. delivery. This is much cheaper than the TSP of £750 with just R2.
    Let your ears/eyes decide though - by the way I didn't look at the others in great detail but you need a Physics degree to work out the remote on the Pioneer - I did -A-level so I am halfway there [​IMG] !!
