Sony DAV-S300 & Other Speakers
Discussion in 'Home Cinema Speakers' started by shaunr, Aug 18, 2002.
  1. shaunr
    shaunr
    Apr 20, 2001
    547
    Darlington - Co Durham
    +17
    Hi all,
    Any ideas how i can attach alternative speakers to the above system. Can the non standard connections be purchased anywhere?
    TIA
    Shaun
  2. kelvin
    kelvin
    Apr 22, 2002
    1,598
    Down South... (Bournemouth)
    +45
    Don't the speakers connect using standard spring clips - I thought it was just the cable connection to the unit that was odd?? Would have thought there'd only be a problem if you wanted to change speaker cable??
    Kelvin.
  3. shaunr
    shaunr
    Apr 20, 2001
    547
    +17
    Thanks for the reply Kelvin, just edited this after re reading your reply...yes it's a method of connecting speaker wire to the unit i'm after. I bought my DAV without speakers, second hand and have Mission 77's to attach.
    Any ideas guys?
    Thanks,
    Shaun
