Sony DAV S-888
Discussion in 'Home Cinema Buying & Building' started by Dogz, Sep 6, 2005.
  1. Dogz
    Dogz
    Sep 6, 2005
    63
    I have a Sony DAV S-888 approx 2 or 3 years old which has hardly been used maybe 30 dvd's maximum. It is now freezing and getting "blocky" after it has been playing a while. Nothing on top of it to cause overheating etc ... any suggestions, i have ran a DVD cleaner disc through it, with little improvement, it still locks up and pixellates etc
  2. ns1col
    ns1col
    Feb 22, 2004
    202
    Aberdeen, Scotland
    Can't help on the blocking/freezing issue apart from suggesting you try and clean the laser head, but you could use the unit as an amp and feed it a signal from another dvd player via an digital optical lead. I use a Samsung HD745 as my player and my 888 as an amp only.
  3. sibleyj
    sibleyj
    Sep 15, 2005
    141
    Dudley
    I have the same problem with my DAV S550. It has also started struggling with some menu screens.
    I have still got a year to run on the guarantee (from Richer Sounds) so I may take it back to them.
  4. frederic
    frederic
    I have the same problem. And mine is 2 year old too!
    Are you happy with the picture and sound quality with you samsung HD745? I was thinking of getting Samsung 950 or possibly Denon 1920?
    I used my S888 with an epson tw200 projector.
  5. rossyl
    rossyl
    Jul 25, 2004
    158
    16
    London
    erm...compressed air can...and spry it about insie. Could be slightly dangerous, but could clean the dust straight off the lens is thats the problem.
