Sony DAV IS10-sound from other components?
Discussion in 'Home Cinema Buying & Building' started by Lil' Joe, Jan 18, 2008.
  1. Lil' Joe
    Lil' Joe
    Dec 28, 2007
    96
    I have the Sony DAV IS10 and it works fine when I use the inbuilt DVD player. But how do I wire it so other components work with the surround sound eg HD DVD player and PS3?
    Do I go HD DVD >HDMI>Sony>HDMI>TV?
  2. table manners
    table manners
    Jan 11, 2007
    665
    the south
    +67
    The hdmi leads will go direct to the tv
    hd-dvd player should have a coaxial output
    PS3 will use an optical output to the dav is10
    If you dont have enough hdmi sockets then run the dav is10 from component (thats if you really need to having a hd-dvd player that will play standard dvds
    to)
