Sony DAV-DZ630 help needed please with getting Sound from TV.
K
karlpalmer187
Hi i recently bought the Sony DAV-DZ630 and hooked it up to my Sony Bravia 40W2000 tv with a QED HDMI cable, it all works fine with the dvd, cd's and tuner, but i cannot get any sound or picture from just the TV running though the home cinema system unless i also plug in a scart lead. i wondered if anyone else had this problem and was there a way of getting around this. Any help please thanks alot.
tiger1310
Hello,
I have just bought the Sony 40W2000 and DAV-DZ630 and hit the same problem as you. Have you solved it yet, and if so, what did you do?
Many thanks...
B
bulaka
Hello,
I have a similar combination: DAV DZ630 & KDL 40U2000. And I have the same problem: with only HDMI connection I don't get the TV sound through DZ630's speakers. When buying the DZ630 I hoped that that the BRAVIA/HDMI control thing would be enough to do this, as suggested on the manual. I don't want to buy a SCART as there is enough cable pollution behind my TV stand :). Any help is appreciated. Thanks,
B.
kentish_lad
HDMI is out only from the 630, to get the TV's sound through the amp you need to connect phonos(red/white) from Tv to amp, to listen to Tv sound press the function button on remote
B
bulaka
Thanks. That works, but I got the sound through the LINE not TV (as expected). I was really hoping (after reading the HDMI control guide) that my BRAVIA (somehow magically) could give the TV sound to the 630 :confused: through HDMI. Apparently not. In any case, thanks for the tip.
B.
Zingari
I've just bought this to run with my Panny Viera. I was told that all I needed was the HDMI cable between the Dav630 and TV - as the HDMI carries both vision and sound.
All I get is a blue screen when using the function button to get TV or Line on the display.
Why do you need to connect the phonos :suicide:. And then do you need to turn down the TV volume for the 630 to take over?
The manual is pants and does not explain things well. and after 5 hrs wiring everything up its lucky the patio door wasn't open as that was where it was heading!
kentish_lad
Firstly HDMI is OUT only from the 630, so the only way to get sound from your TV to the 630 is via phonos (red/white)
Zingari
I've now managed to get the sound up and running with the TV but I take it if I want to give primacy to the theatre system I have to keep it on and turn down the TV audio?
Also is there no way to adjust the treble/bass and individual speaker levels?
kentish_lad
see page 81 and 82 in the manual for levels
