sony dav-dz500 divx help please
Discussion in 'Home Cinema Buying & Building' started by maximus desimus, Oct 27, 2005.
  1. maximus desimus
    maximus desimus
    hi all ihave the sony dav-dz 500 all in one player
    i cant get any divx discs ive recored to work at all
    i was thinking about upgrading the firmware from the sony digital site but ive used the service remote from multiregion upgrades and i think if i upgrade the firmware this will set it back to region 2 player and wipe out the multiregion upgrade all my divx disc keep saying can not play.....
    is this correct abot the firmware
    does anybody have any advice please
    Shaun
  2. Corpse
    Corpse
    It may be that the divx disks you recorded are in xvid format which isn`t supported.
  3. ash
    ash
    Jun 9, 2005
    11,320
    +398
    What! NOT SUPPORTRED :eek:
  4. pplucky
    pplucky
    In what concerns to the multiregion upgrade, it seems to me that is done at firmware level, so if you install a firmware update, most probably your multiregion settings will be gone.
    I recently bought one of these too, and yesterday I had a pleasant surprise, when I tried to read XVID video files and I managed to do it!
    Still then, I also have some AVI files which I'm not able to play: Data error.
    One more thing, check this tool: http://gspot.headbands.com/ to know exactly which codec is needed to read your AVI files.
    Another thing: I already installed the firmware update and worked 100% in what concerns to reading independent file subtitle files.
    Hope this helps,
    Nuno
  5. ash
    ash
    Jun 9, 2005
    11,320
    +398
    So with the multirefion upgrdae will xvid work?
  6. pplucky
    pplucky
    Dunno!
    What I know is that I installed the firmware update from Sony to allow the subtitles from files and the player is able to read XVID files with no problem. Still then, I have other files which can't be read (neither DivX certified or XVID).
    I believe that if you install the firmware update first and then the multiregion upgrade, it should work, because the firmware update from Sony simply replaces the existing firmware information and the multiregion upgrade most probably only changes the necessary info to play DVDs from all regions.
    Although this is a wild guess... it makes sense!
  7. biggazz
    biggazz
    Thanks for this guys,the update works a treat.
    Can anyone point me at the region hack,I have had a good scan round and cannot find it,
    Gaz
  8. ash
    ash
    Jun 9, 2005
    11,320
    +398
    Mm.. Mine is MR now.
    Do I update to play Xvid which I need or keep it MR. Mmmm....
