sony dav-dz260 divx???
Discussion in 'Home Cinema Buying & Building' started by pea69, Feb 3, 2009.
  1. pea69
    pea69
  2. Steeve24
    Steeve24
    Nov 25, 2008
    125
    +8
    Yes, from what I have seem the 260 doesn't have divx playback when in UK spec, but as it is Pixmania & they are French (I believe) it could be a Euro version supplied with a UK plug. No idea if the Euro one can play Divx either?
    Short of getting it and checking I wouldn't bank on it being able to play Divx
  3. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    the european version does play divx, the uk version does not.
  4. pea69
    pea69
    will the european version be ok to use here? i won't have any compatibility problems will i?
    and will it play divx from the usb drive on a memory pen?
  5. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +4,289
    no, strictly disc only,either dvd or cd.
