Sony DAV 550
Discussion in 'Home Cinema Buying & Building' started by millsy, Jul 24, 2003.
  1. millsy
    millsy
    Aug 14, 2002
    59
    Manchester
    Hiya
    My mate has a DAV 550 and I was listening to it the other day and noticed that the volume when watching a DVD is a lot lower than say watching NTL or listening to radio through it. Is this normal and is there a way of increasing the volume for DVD's as at MAX I would say it is not loud enough. Or is this normal?
    thanks in advance.
    Ian
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,558
    7
    167
    Birmingham, UK
    +10,395
    In my limited experience, I'd say yes. Both fed into my amp, the DVD source was quieter than Sky with 2 players and a home cinema PC.
    There is sometimes a DVD output volume tweak in the menu. See if you can find one.
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    That's standard with the davs 550, nothing can be done AFAIK. They're just not very loud with DVD.
  4. njiri
    njiri
    Oct 26, 2002
    149
    19
    UK
    I had a Tosh SD220, dvd was VERY quiet compared to a CD at the same volume setting.
  5. millsy
    millsy
    Aug 14, 2002
    59
    Manchester
    Thanks for everyones help.
    Ill let him know you cant do anything.
    cheers
    Ian
