Sony da5es "thump" on power up?
Discussion in 'AV Receivers & Amplifiers' started by bikejog, Apr 27, 2003.
Tags:
  1. bikejog
    bikejog
    How many da5es / va555e owners out there experience a "thump" sound on one of the amp channels when powering up the receiver after leaving it off for a few day or a week?
  2. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    Naughty naughty........surely you turn your volume control to zero before you power up??:lesson:
  3. bikejog
    bikejog
    Haven't try turning the volume down, but I think it does not matter because there's a time delay on the preamp. I can hear a relay click after a few seconds and then the music comes on. The "thump" comes on before the music comes on.
    Does it happen on your STRVA555ES? I think it might be something wrong with mine.
  4. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    No 'thump' on mine, but as I said before, the volume is always at minimum before power up or power down.
    Its good practice to do this????
  5. bikejog
    bikejog
    If you need to do that your equipment, then what good is the "power on" button on the remote?
  6. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    You can turn vol down via remote before you power off..:D
  7. bikejog
    bikejog
    You win... :) Never thought of that one. But I think you should not have to do that. I have V1.3 of firmware, will upgrade to V1.74 tonight. See if that helps, if not, then anyone knows the Sony parts number where I can buy a schematic of the 5?
  8. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    :D Read years ago that its a good idea to turn volume off before amp power up and down. Remember a few years ago, left my Technics amp at VERY high volume, and when I turned it on again, nearly s*** myself from the BOOMB!! It can damage your speakers too..:lesson:
    Good luck with the upgrade, Proper 6.1,here you come.:D
  9. bikejog
    bikejog
    Haven't no luck with the upgrade yet. Got the wrong type of cable I think. Hope I didn't blow the UART on the receiver. Oh well... Off to Microcenter I go..
