sony DA3000ES
Discussion in 'AV Receivers & Amplifiers' started by mattty, Mar 19, 2005.
Tags:
  1. mattty
    mattty
    I have a second hand sony DA3000ES and on the back of the amp it has 2 scart sockets but in the manual it doesn’t, anyway can I connect one of these to the tv and run the ps2 and Xbox leads into the amp. Thanks
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    You should be ok anyway, get a scart to s-video or composite conversion cable and you can do with out the scarts on the amp end.
