Sony D800U no epg or menus since v12 upgrade
Discussion in 'Satellite TV, Sky TV & FreeSat' started by macta, Oct 31, 2004.
  1. macta
    macta
    Has anyone else noticed their sony box have the epg or menus disappear since the upgrade to v12?
    Twice now my box has not showed the epg when I press the epg button nor the menu's however the ch+/- buttons have continued to change channels?
    The first time a standby on/off corrected it, the second time I had to do a reset (e.g. press power for 6 seconds) and it corrected itself.
    Anyone else notice this? After the upgrade I didn't do a full reset so I am hoping its that but its a bit worrying.
    Tim
  2. adrianl
    adrianl
    No probs since I upgraded to v12. I haven't actually reset since, just gone to standby and back, The new version now appears ok in the technical menu though.
    Adrian
  3. sdc395
    sdc395
    Apr 1, 2003
    197
    19
    UK
    A few people have reported minor problems since the upgrade (although this one is new to me). AFAIK, all but one has been solved by a reset. The unresolved issue relates to the MHEG's on the BBC's time-sharing channels popping-up when they shouldn't.
