Sony D800u: Lack of Stereo Output
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Ian Roberts, Sep 6, 2005.
  1. Ian Roberts
    Ian Roberts
    I have a D800u receiver & do not seem to be able to get a stereo output to my TV which I'm sure I had in the past. Done the normal things of checking & swapping the scarts, any ideas ?
  2. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,277
    +100
    When you say it's not in stereo, are you refering to a mono sound eminating from both speakers or just 1 speaker working?
    If mono from both try reseting the box.
  3. Ian Roberts
    Ian Roberts
    Hello
    Mono in both speakers ( analogue works fine in Nicam Stereo). How does one re-set the box ?
  4. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,277
    +100
    Easy. Just hold the on/off button on the box in for 8 secs. Release and the power light will go orange then red and then turn itself on. Also check your audio settings on your TV for scart i/p's if you have any.
