Sony D50Q
Discussion in 'Projectors, Screens & Video Processors' started by Bruce Shearer, Jul 1, 2004.
  1. Bruce Shearer
    Bruce Shearer
    Does anyone have ideas on possible faults which cause excessively high screen voltage on the Green tube of a Sony D50Q?
    Any suggestions gratefully accepted.
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Go you mean your picture had gone all green. Or that the EHT has gone high on the green channel?
  3. Bruce Shearer
    Bruce Shearer
    Would appear that the Green bias is set too high giving a definite green cast to Black. Not able to set the Green bias via the software. Also would appear that there are two different versions of firmware with the D50s - one where you can adjust Green bias through Service setting, the other version doesn't allow adjustment. Is this correct?
