Sony CX850 AND CX860 together
Discussion in 'Blu-ray & DVD Players & Recorders' started by graham.myers, Jun 5, 2002.
  1. graham.myers
    graham.myers
    I currently have a CX-850 and its full.
    I have been toying with the idea of getting rid and purchasing a Progressive scan player.
    But I do like just dialling a disk.
    So, I'm also toying with the idea of getting a CX860 (the 301 disc model) and using the component output of that for films, and the S-Video output from the CX850 for TV series and extras discs etc.
    My question is will the remote codes interfere with each other and can you set them to distict frequencies so they won't intefere?
  2. graham.myers
    graham.myers
    another thought.
    My PJ is a 10HT. If I remember previous threads correctly is does a reasonalbe job of producing a progressive scan display.
    I believe the 11HT does a much better job.
    If I go for a CX860/CX850 combination should I flog off my 10HT and get an 11HT (or sim or whatever) to get as a decent prog scan from these sources.
    Or should I scrap it and get a PS DVD player and bypass the onboard deinterlacer on the PJ.
  3. Me
    Me
    Aug 17, 2001
    132
    Wiltshire
    +5
    I use both the Sony CX850/860 with no problems. I had a demo of the Toshiba 510 prog scan player and to be honest the Sony gave an equally good picture through S-Video. I will definately not be parting with any money to get this player and scrap the Sony.
    Remember the CX860 does not output progressive scan, only has a component output.
    Mark
  4. graham.myers
    graham.myers
    Me,
    did you have to do anything with the remotes so they don't send the same signal to both players, or are they distinctly different signals so my pronto will be happy.
  5. Guest
    The new 875 has prog scan + MP3 playback (+ more).
  6. graham.myers
    graham.myers
    No details on Sony site - do you have any details?
  7. Guest
    There's a pdf file out there to be found (i.e., google). If you don't find it I'll send you mine.
    Mike.
  8. Me
    Me
    Aug 17, 2001
    132
    Wiltshire
    +5
    Graham. No problem, they just worked out of the box.
    mark
  9. richkeys
    richkeys
    Jan 16, 2003
    19
    London UK
    do you still have the 860? are you selling it?
