Sony CRT VPH 1041 QM
Discussion in 'Projectors, Screens & Video Processors' started by yejaffe, May 21, 2002.
Thread Status:
Not open for further replies.
  1. yejaffe
    yejaffe
    Would like to hear your opinion on the Sony CRT VPH 1041 QM. It is around 6 years old.
    Is it still possible to get parts for it and how much should it cost to change the red tube?
    Will it provide a decent picture in 30-40% light in the room?
    I can get it for around 500 pounds, does it worth?
    Thanks,
    Jonathan
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    Sony 1041 - old analogue chassis projector with manual convergence. Not capable of line doubling.
    £500 seems OK if it is working fine. If you need to replace the red tube on top of that price I would walk away. Combined cost would get you a warrantied S/H Barco with higher spec and possibility to line double. Speak to Gordon (Convergent AV) or Roland (B4) for further details.
    Regards
  3. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Recon on about £700 to have the red tube replaced.
    It was a nice dinky projector in its time.
    Check that age though it must have been one of the very last units.
    Bad luck on the lighting level though.
Thread Status:
