Sony code for Denon remote
Discussion in 'AV Receivers & Amplifiers' started by John G, Jun 2, 2001.
Tags:
  1. John G
    John G
    Nov 25, 2000
    307
    Matlock, Derbyshire
    +54
    Does any one happen to know if there is a code for the AVR 3801 remote to operate Sony equipment? There doesn't seem to be one in the list supplied with my amp.Does this mean I won't be be able to use the new remote or is there a way round it.Any ideas gratefully recieved.Thanks,John
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,493
    United Kingdom
    +2,030
    I had the same problem with my 3801 as there are no codes for yamaha cd players. Fortunately the remote supplied has learning capabilities. Have a quick flick thru the manual & it should tell you how to go about it. I cant remember it all off hand but you have to press the amp button on the remote until it says Learning. I just programmed the basics PLAY, STOP etc etc.
    Hope this helps
    cheers
    jase :)
  3. John G
    John G
    Nov 25, 2000
    307
    Matlock, Derbyshire
    +54
    Thanks Hooty,I'll give it a try.Regards,John
