Sony CMT-A50
Discussion in 'Hi-Fi Stereo Systems & Separates' started by earwax, Sep 21, 2005.
  1. earwax
    earwax
    Apr 2, 2005
    338
    +6
    Probably this is beneath most as it is only a cube type format, receiver, tape deck and cd plyer but nonetheless I would appreciate some advice.
    I live in an area that is subject to local power outages. unfortunately I found that the Sony CMT-A50 loses all its settings so I have to tediously rest every time and outage occurs. Had I known I would not have bought the model- why don't they put essential info like that up front and not in the middle of the instruction book?- grrrr!
    Question: Is there any way to install a battery back up so that I retain the settings during a power outage?
  2. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    You could run it through a suitably specc'd PC type UPS(like the Belkins etc that most of the big PC retailers sell),and given the power requirements of your Sony,one of those should be sufficient for a considerable length of time if the CMT-A50 is in standby during a power failure.
  3. earwax
    earwax
    Apr 2, 2005
    338
    +6
    Thanks. I am not very up in terminology. What is a <<PC type UPS..? Have you a particular model in mind and what are the essentials to consider in specs?
  4. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
