C
Cas141
I need advice about the screen resolution of the new HS10 : Would I would be able to use it. ? You see, I would be using it with my Personal computer, and although I would occasionally play DVD films through it, the main reason for using a projector is to play flight simulator games.
The resolutions of PCs are 800x 600;1024 x 768;1152x 964; 1280x 1024 etc., as you may be aware, and most games are written to run in one or more of those resolutions. There is not a 1366 x 768, which is the spec of this new Sony.
My screen will be a 6ft wide by 5ft deep, ( max) window blind screen.
I would like to play the sim in 1024 x 768 ( XGA) .
Does this spec of the Sony HS10 mean that it will not be a suitable projector for me, or, if I can use it, in what manner, mode etc must I do so?
I know it is early days as the thing isnt released yet, but I am hoping for some guidance.
I havent used a projector before.
TIA
TIA
