Sony Cineza HS1 service menu
Discussion in 'Projectors, Screens & Video Processors' started by elche99, May 10, 2002.
  1. elche99
    elche99
    Apr 19, 2002
    20
    Hello all,
    I've seen that you can enter the service menu from the remote with the following sequence:
    -enter
    -enter
    - up
    - down
    -enter
    at this point you are requested to push
    -up
    to enter the service menu.
    I've read that in this "service mode" you can fine tune Red, Green and Blue channel to have a more well balanced image than in factory default.
    Ok, I entered the service menu in my Cineza BUT I didn't find anything that can modify R,G and B channel; I've tried it with RGB from computer, RGB from satellite and also with Component from DVD.
    Someone has an idea?
    thanks in advance
    elche99
  2. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,608
    Stoke
    +56
    I did it with mine and the picture is MUCH better now- it had a green caste before. I will have a look and let you know what i changed. It's definitely in the menu under picture settings as I recall
  3. elche99
    elche99
    Apr 19, 2002
    20
    Could you give me the EXACT location of the RGB fine tuning on the service menu?
    many thanks in advance
    bye
    elche99
