Sony Cdx-l280
Discussion in 'Video Streaming Boxes & Services' started by DARKGUARDIAN666, Mar 28, 2005.
  1. DARKGUARDIAN666
    DARKGUARDIAN666
    I have just bought a CDX-L280 which has come out of a renault clio.
    I have a 1995 ford mondeo and have had a look on websites to find the right convirsion kit.
    Can anyone please help as the wiring loom i have seen does not seem to look like the conector that goes into the cd player. :lease:
  2. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,334
    +6,868
    The Sony should have been supplied with an ISO cable which is 2 x 8 way connectors at one end (ISO) & the standard Sony connector at the other. If this is missing then replacements are readily available. It's then a question of whether or not the Mondeo has ISO connecters. If not you will need an adapter to match. I don't know the answer to that.
    Once you have established what you need there are many Internet suppliers like this. If you're still unsure, get them to tell you what you need.
