Sony CCD-V100E User guide
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by loub, Sep 19, 2007.
  1. loub
    loub
    Hi everyone,
    I have a Sony CCD-V100E, but unfortunately without the user guide.
    I haven't used for a long time, but decided to digitize my old tapes.
    It started working great, but now I have a sign that appears that blocks me from using the play mode of the camera. I can't even eject the tape.
    The sign is like a water drop that blinks.
    Does anyone have the user guide or know what this sign mean?
    Thanks a lot
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Sounds like it is telling you there is condensation. It should clear if the camcorder is in a warm dry place. If it doesn't you could try cleaning the heads.
  3. loub
    loub
    Thans for your quick answer.
    It sounds logical, but why is humidity a problem?
    Because it seems to be very sensitive as the place where my camera is placed is not that humid.
  4. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    Normally you only get that if you bring a camcorder from a very cold place into the warm. And it would clear up in a short time. If it is stuck showing that then something is wrong.
  5. loub
    loub
    Ok, thanks...
    I'll try cleaning the head and I hope it gets better. At least to give me some time to digitize the tapes I have... then I don't care :)
