Sony Camcorders - PC style or 'Normal'
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Neiliboy, Sep 1, 2004.
  1. Neiliboy
    Neiliboy
    May 13, 2003
    205
    16
    Cambridge
    Hi can anyone tell me if the shape of the camcorder makes any difference to its performance?
    I was thinking of getting a Sony PC style 'upright' one as i like the size and shape, but thought its best to ask on here first.
    Many thanks,
    Neil
  2. Roy Mallard
    Roy Mallard
    Upright cams are great for convenience and compactness, and in theory there is no difference in the components used for an upright cam or a conventional cam.
    However, because of the compact design many cams have thir mics on top of the camcorder, right next to zoom lens and motor, on most that i've seen the mic is also right next to the major controls (i.e zoom), so it's been my experience that upright cameras have more handling noise etc.
    You also tend to use the menu more as there is less external space for function buttons and things like hotshoe mounts.
    My advice would be:
    Avoid the JVC's
    Definately avoid sony IP's
    For quality go for a PC330 (preferably try and get a bargain with a PC120!, they were great cams, as they have been superceded you should get one fairly cheap, say around £650).
    For absolute compact size look for a canon MV6/10
    You will get better value buying a conventional cam, probably more connectivity (eg hotshoe, mic input), but they are bigger.
    Having said that, the panasonic GS cameras are probably smaller in every dimension than a PC330.
  3. Neiliboy
    Neiliboy
    May 13, 2003
    205
    16
    Cambridge
    Thanks for the response Roy - the PC330 was exactly the one i was thiking of going for. I dont want a particularly fancy camcorder, but it must be a sony as it will be compatible with my PC, DVD RW, Camera etc.
    Now i've just got to go and get me a cheap one somewhere!
    Many thanks,
    Neil
  4. erne
    erne
    The update to the pc330 the PC350 can be picked up 4 ubder £800
    I have one and am impressed
    regards
    ern
