Sony Bravia Vs. Panasonic LCD TVs - Which is best?
Discussion in 'Panasonic TVs Forum' started by diykanu, Dec 19, 2006.
  1. diykanu
    diykanu
    Having decided to buy a new LCD TV, would anyone be able to advise which of these two is the better option: Sony Bravia KDL 26S2030 26" (maybe 32")OR Panasonic TX26LXD60 26" (maybe 32"). If anyone has experience or advice on either of these models/ which to buy, it would be most appreciated!
  2. panlee
    panlee
    General opinion is Panasonic is stronger in its plasma range, together with Pioneer and Hitachi.
    For LCD, the top are (in no particular order) Sharp, Toshiba, Samsung, Sony and Philips.
  3. lord-dudester
    lord-dudester
    Oct 27, 2006
    2,232
    Spalding Lincs
    +269
    well the s series sony does have a few things going for it although my 32' s series has been nothing but a pain since ive had it (lots of probs with panel)
    the pana's always gonna top it for reliability, although correct me if im wrong, it dont have a pc input?
  4. richierich-not
    richierich-not
    Jun 29, 2006
    16
    3
    can`t comment on the sony but i`ve had the panny for 6 months,picture quality thru sky is great,dvd playback thru upscaled hdmi really vibrant,even the footy looks good with none of the usual motion blurring-only let down is the sound which is a bit `tinny`-got mine thru surround speakers so it`s not really a problem.seen this advertised with digitaldirect for under £600 which i reckon is a bargain!
  5. dacco
    dacco
    Dec 12, 2002
    193
    +5
    Yup you're right, no PC input on the LXD60.
  6. diykanu
    diykanu
    THanks Panlee - Can I just ask where you got the info to devse your 'top 5' list of LCD producers??
    Thanks!
  7. panlee
    panlee
    For top 5 sorry if I misled, I should say in my opinion... I heard it from sales rep
  8. emrysdavies
    emrysdavies
    Aug 18, 2005
    455
    +14
    Only a little point, just in case it helps you: the 26 in this number 26S2030 indicates that it is a 26" set.
  9. diykanu
    diykanu
    THanks for clarifying - I did suspect as much but just wanted to be sure! I'm not too clued up on these things, as you can probably tell...
