Sony Bravia Stand Removal?
Discussion in 'Home Cinema Buying & Building' started by janet77, Mar 19, 2006.
  1. janet77
    janet77
    I hope you can help. I want to remove the stand from my Sony Bravia KDL-V32A12U and don't want to start unscrewing everything at random. There seems to be no help in the manual or on Sony website.
    Thanks for your help!!!
    J
    :lease:
  2. Hi/zuum
    Hi/zuum
    Oct 4, 2005
    3,916
    Nottingham
    +400
    Arm yourself with one standard screwdriver. Unscrew the four screws at the lower back of the TV & out slids the whole metal unit with the stand still attached. It's so simple, it should take you no less than 2 minutes. ;)
  3. janet77
    janet77
    Thank You!
  4. m33ufo
    m33ufo
    Dec 1, 2005
    1,128
    38
    Wales
    +10
    Hi there, I am trying to remove the stand from mine, so far no luck. I have a KDL-V40 which I assumed would be the same??
    Any advice welcomed.
    Mark
  5. total novice
    total novice
    Hi, i have the KDL-V40A12U as well and can not find out how the stand comes off.any ideas folks!!.i need to wall hang it in my boys bedroom and theyre getting fed up with me .please help:lease:
