Sony bravia "s" or "l" series?
Discussion in 'What Is The Best TV For You?' started by Fyog, Jan 29, 2009.
  1. Fyog
    Fyog
    Jan 29, 2009
    5
    Hi !
    Please does anyone know where i can get the Sony Bravia KDL32S3000 cheaper than £489? that's a bit pricey for me so i'm thinking about going down a series or two to the "L" model because like the "S" model, it's also in matt black. is the "L" worth getting, as i know it's an older version ...?
    thanks!
  2. boxrick
    boxrick
    Jan 26, 2007
    3,037
    +304
    32s3000 is an older model... avoid it... the 32l4000 is also a terrible television doesn't even have the bravia engine.
    Look at the KDL32V4000 as a mininum -- or if looking for better the v4500 or w4000..
    However i would consider either Panasonic TH32LXD85 for £400 or LG32PG6000 plasma .... both better in there own respects. I own the lg and its an excellent screen.
  3. Fyog
    Fyog
    Jan 29, 2009
    5
    oh! :eek:
    now i'm more confused cos i've read somewhere that the s series is the newest model out now. i defo want a Sony, so am i right in thinking you would choose the V over the S series then ...? :rolleyes:
  4. bushmonkey-ps3
    bushmonkey-ps3
    Jan 29, 2009
    25
    3
    i think the L series are the newest ones aren't they?
  5. boxrick
    boxrick
    Jan 26, 2007
    3,037
    +304
    S3000 is old
    S4000 is new...
    s4000 is basically same as v4000... L4000 is a pile of doggy poop. However as i said i would not recommend any ... look at the LG or Panasonic sets... nicer looking , better PQ, better sound, deal with motion better. They also don't feature the ugly 1970s speaker that the v4000 has stuck onto the bottom.
  6. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    although panasonic has great tv's the 32V4000 is an excellent piece of kit and the design is still acceptable.for sth better aesthetically look at 32S4000 which is the same technically as 32V4000 but with different design.avoid 32L4000 its a poor basic model
  7. Fyog
    Fyog
    Jan 29, 2009
    5
    hi again, just to confirm... the s4000 is newer/better than the s3000 version then?
  8. alsina
    alsina
    Nov 30, 2008
    3,796
    +605
    Yes. 3000 models are last year's tv's. 4000 are the current models.
  9. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    yes S3000 is last year's model
  10. Fyog
    Fyog
    Jan 29, 2009
    5
    thanks muchly.
    I think it's the Sony S4000 for me then. just need to find the best price. anyone seen them "cheap"? i've seen the S4000E but from what i've learned so far, that's the European version and it may not work properly in the UK, so i don't want that one.
    so far ive found one for £489.:rolleyes:
  11. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    in UK the 32S4000 is a sony centre exclusive,so what about going to a local sony centre and seeking a good deal?
