Sony Bravia "No Signal" on Freeview channels
Discussion in 'Freeview & YouView' started by okratpack, Aug 13, 2013.
  1. okratpack
    okratpack
    Aug 13, 2013
    3
    I have a Bravia KDL 46EX500. I have always had cable until now. I went in and set it to antenna and went through the auto channels and it found none. Continues to say "no signal". When I use a digital converter box and put the tv on channel 3 I at least get a weak signal message. Any suggestions? I am sure I have left out details so please don't hesitate to ask.
    Thanks in advance!
  2. A1944
    A1944
    Jun 16, 2010
    778
    46
    +107
    Starting points would be:
    Where are you (roughly)?
    Do you know which transmitter you should be using?
    What kind of aerial are you using and whereabouts is it located?
  3. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    Also what is the 'Channel 3' you are get a 'weak signal' message on? Are you referring to a Digital/Freeview channel or the, now redundant, Analogue service. Scanning TVs will look at both bands and may pick up some spurious signals in the old frequencies.
  4. okratpack
    okratpack
    Aug 13, 2013
    3
    Thank you A1944 and Mike for your questions and help with this.
    More details: I am in Western Montana. I have searched on the gov. websites where it shows you what channels you should get with an antenna. It says that I should get 3 different channels that are broadcasting Digital signals.
    I just purchased a LAVA HD-2605 Ultra Antenna. Specs on that are VHF:40-300MHZ 28-32dB and UHF:400-890MHz 32-36dB. I have tried it on the rooftop which should be sufficient. When that is hooked up (Without the redundant digital converter box which I should not have to use) I get "no input signal" - Nothing, Nada. When I try and "add Digital Channels" or Scan Channels it finds nothing - like my Televisions tuner is not even working. When I plug it into the digital converter box and tune to channel 3 (Mike - the Digital box says to tune to channel 3 or 4 for input) I at least get weak signal.
    That is the real issue here - the TV is not seeing the Antenna at all when connected directly to the television and doing a channel scan. It is like it is requiring a digital conversion and it shouldn't be.
    This is very confusing and I really appreciate your help.
  5. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    :eek:
    No wonder you can't get UK Freeview!
    Suggest you post on AVSForum, which is US based.
    Good luck! :smashin:
  6. okratpack
    okratpack
    Aug 13, 2013
    3
    Oh my that would be a little out of my range. :) Sorry everyone. I apologize for that slip up. Thank you tight Git for the direction.
  7. JayCee
    JayCee
    Jan 20, 2004
    23,486
    Lanarkshire
    +2,532
    The giveaway in a post like this is use of the word "Antenna"
    We in the UK would normally use "Aerial"
  8. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    Yes, if only the OP was reporting a color problem in a Home Theater system that had cost $2,000 last fall, we might have guessed! :laugh:
  9. Rodders53
    Rodders53
    Dec 8, 2007
    5,128
    Bedford
    +918
    Unless you are an Engineer or scientist and need to use the correct technical term which is... :devil: antenna
    <ducks>
