Sony Bravia KDLV32A12U and Oppo 971 Help needed !!!
Discussion in 'LCD & LED LCD TVs' started by Turb007, Sep 14, 2005.
  1. Turb007
    Turb007
    May 16, 2004
    3,308
    Bromley, Kent
    +661
    I bought my 32" Bravia last week and my Oppo 971 arrived yesterday. As you can imagine a great evening setting it all up calibrating etc however ...
    PAL wont work through DVI :mad:
    connected via DVI-HDMI lead it works on AUTO, NTSC but if i set the player to PAL only the sceen goes blank ..i dont even get the oppo logo screen ..nothing.
    My request is that if you have this same set up could you try this as well and confirm if its the same for you.
    I have been onto oppo and they have been really responsive with support so no complaints there ..the same with ITsupplies.net ..top service :clap:
    Oppo suggested that its a hetrz through DVI issue . just would like to know if its a bad combo of screen or player
    Huge TIA
    Turb007
  2. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,310
    The screen should have no problem accepting 50hz over the HDMI port.
    Set it to AUTO and play a PAL DVD - does the picture disappear?
  3. Turb007
    Turb007
    May 16, 2004
    3,308
    Bromley, Kent
    +661
    yes it does ..
  4. Turb007
    Turb007
    May 16, 2004
    3,308
    Bromley, Kent
    +661
    bump
