sony bravia kdl-v40a12u set up
Discussion in 'Sony TVs Forum' started by ash005, Mar 21, 2006.
  1. ash005
    ash005
    Nov 20, 2003
    244
    +8
    just bought one of these yesterday from comet
    got a very good deal
    but now need to set it up
    at the moment its just connected to an aeriel
    just wondered if anyone can offer some guidance as its the first lcd tv ive owned
    had the sony 28" its replaced for 10 years!
    cheers in advance
    ash.
  2. kourosh
    kourosh
    Feb 6, 2005
    14,930
    Portsmouth
    +1,110
    dont buy cheap leads:smashin: you dont have to by the most expensive,but dont buy the cheapeast.
    dont forget lcd dont hide bad signals as good as tube sets
  3. ash005
    ash005
    Nov 20, 2003
    244
    +8
    cheers mate
    at the mo its hooked up to a panasonic hs2 via scart
    will hopefully sort out the connections at the weekend when my hdmi dvd player turns up
    ash.
  4. ahin4114
    ahin4114
    Nov 1, 2004
    1,066
    Reading
    +48
    Hi Ash, welcome to the forums.
    As a hint, it may be useful if you posted details of what kit you are trying to connect, then people will be able to give you a better idea of how to connect it all up.
    If you're after settings for picture then there's plenty to choose from on the Owners thread, I've also had PM's from several people who got very good results with mine. Don't worry about using the service menu for now.
    Also bear in mind these sets look better after a couple of days of use, so don't get disheartened if the picture isn't perfect from the minute you turn it on.
    Tony
  5. ash005
    ash005
    Nov 20, 2003
    244
    +8
    cheers tony
    ok
    at the moment im hooking it up to;
    an aerial - freeview & normal tv
    a yamaha ax-2 - ive had it a while and it may get updated - with kef fronts, centre & a yamaha sub - no rears at the mo -
    a pioneer laserdisc - don't ask
    a panasonic dmr-hs2 multiregioned dvd/hdd machine
    all i did last night was pull the old tv out of the way and plug in this one the same (using scarts), with the exception of adding in a monster 800 power supply thing (freebie from comet!)
    i have a lg hdmi dvd hopefully turning up before the end of the week and will probably have a good go at getting it set up right then
    the room is approx 6m X 6m with a ceiling height of 2.7m, the set is in a corner - i know, but i like being married!.
    was thinking of a yamaha sound projector as a future purchase
    this is all a kind of stop gap until i can complete my cinema room which is currently an empty cellar with no floor
    must say i registered on here ages ago and have found the info available very helpful so far
    cheers
    ash.
