Question Sony Bravia KDL-32W706B
Discussion in 'Sony TVs Forum' started by bigdam, Apr 1, 2016.
  1. bigdam
    bigdam
    Mar 23, 2013
    Hi guys,
    So while I was moving out mum has managed to lose the bag that contained the power supply stand and remote to my telly..
    So now am in need of the above but don't fancy spending a fortune on them can any of you guy recommend me a good place to go I assume the don't need to be Sony parts of possible?
    Thank's
    Dam
  2. JayCee
    JayCee
    Jan 20, 2004
    22,730
    Lanarkshire
    +2,398
    The stand will be unique to Sony models so yes, it will need to be a Sony one.
    You can probably buy a "Pattern" remote on the web which will be cheaper than the original...a "Pattern" or "Replacement" remote is a button for button replacement just not made by Sony.
    As to the psu, you need to check the voltage and current requirements of the Tv and if the power pack has a non-standard plug at the end...you should be able to check this either in the set's user manual or it will be printed on a label on the rear of the set.
