Sony Bravia KDL-32V4000
aliman5000
Afternoon all,
Can anyone confirm 100% what the maximum resolution is when using VGA please? I have read conflicting stories between 1280x768 and 1366x768...
I currently use VGA and a KVM switch for 360 and PC into Samsung LCD running 1366x768, if the max supported VGA res of the Sony is anything less than 1366x768, not only will I be annoyed, I will also need to shell out for a DVI to HDMI cable for PC and *possibly* a new 360 with HDMI port to achieve the desired resolution.
Please help!
Dankeech
Hi Clown X,
I don't know your TV, but it certainly should have copmponent-in so you can run your existing xbox 360 at choice of 1280x720(720p) and 1920x1080(1080i) using the red, green and blue connectors on your Xbox 360 cable.
Vga resolution is something that should definitely be in your manual by the way.
Hope that helps.
Dan.:)
