davieg1
Established Member
As above, I bought this tv tonight for wifes mum & dad`s living room tonight at Sainsburys
Product Information
The Sony Bravia KDL-32U2000 has built-in Freeview, for a wide choice of digital channels, and has a tabletop stand, so you can place it anywhere as soon as you get it home.
Its 3D comb filter and high resolution gives you a bright and sharp picture, while its Electronic Programme Guide lets you have full access to TV listings for a week. Picture in Picture freezes important scnes on the spot so you can get a closer look.
The KDL-32U2000 has a PC socket so you can use it as a computer monitor if you're trying to save some space or don't have a separate office. If you're prone to nodding off, take advantage of the Sleep Timer – you can set the TV to automatically shut down to standby after a certain amount of time.
This television is ‘high definition ready' which means it has the ability to display high definition signals with the addition of a separate HD receiver. HD broadcasts are at a much higher resolution than regular analogue or digital broadcasts and have greatly enhanced picture quality. The level of detail is astonishing with clearer, sharper and more vibrant images.
Key Features
Audio quality Virtual Dolby Surround sound
Auto setup Yes
Brand Sony
Brightness 450cd/m2
Contrast ratio 1200:1
Digital tuner Yes
Dimensions H58 x W80 x D22cm
Fastext Yes
HD Ready Yes
HDMI inputs 1
Model name / number KDL-32U2000
On-screen menus Yes
Remote control Yes
S-Video socket No
SCART sockets 2
Screen format Widescreen
Screen resolution 1366 x 768
Screen size 32"
Speaker output (RMS) 20W
Stand Included
USB ports No
Visible screen size (measured diagonally) 80cm
They are delighted with tv and all I need now is a nice glass table for them
ps: Staff discount is 10%, if you know anyone that works there , so I got it for £450
Product Information
Key Features
Auto setup Yes
Brand Sony
Brightness 450cd/m2
Digital tuner Yes
Fastext Yes
HD Ready Yes
HDMI inputs 1
On-screen menus Yes
Remote control Yes
S-Video socket No
SCART sockets 2
Screen size 32"
Stand Included
USB ports No
