Sony Bravia 40W4000 Settings
Discussion in 'Sony TVs Forum' started by Usama, Jun 1, 2008.
  1. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
    I have ordered a Sony Bravia 40W4000. It is going to be delivered on Wednesday. What would be the best settings for it, what should i change?
    Thank's
  2. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    You can start by applying the HDTV TEST settings
  3. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
    Will thoes be the best settings because normally i don't like the cinema mode. It is too dark.
  4. zophiel
    zophiel
    Mar 18, 2008
    13
    3
    I use the following at the moment for the sky+ SD broadcast.
    Picture Menu
    Picture Mode: Standard
    Backlight: Min
    Contrast: 65
    Brightness: 65
    Colour: 53
    Temperature: Warm1
    Sharpness: 10
    Noise Reduction: Low
    Mpeg Noise Reduction: Off
    Picture Menu Advanced Settings
    Adv. Contrast Enhancer: Off
    Colour Space: Standard
    Features Menu
    Quick Start: Off
    Power Saving: Standard Power
    Light Sensor: Off
    Logo Illumination: On
    Film Mode: Auto
  5. YellowSphere
    YellowSphere
    Dec 2, 2007
    4,448
    103
    +471
    Definitely. If you still find it too dark on these particular settings when raising the backlight control, you must have one heck of a bright room.
  6. naruto
    naruto
    Feb 25, 2008
    90
    Dublin
    +28
    I ran the DVE BD calibration disc and found the default cinema mode came very close to passing all of the tests. Similar to the HDTV test settings I didnt deviate all that much from them. However they arent perfect for SD(will try zophiels SD settings tomorrow)
    Ps3 settings that need changing for the W4000 are RGB to limited and Superwhite enabled
  7. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    yeah some find it dark,but I cant comment further as I havent tested them
  8. krlock3
    krlock3
    Aug 20, 2007
    643
    +25
    i find the hdtv test settings way too dark in daytime, so i stick to "standard". In the evening the darker picture looks better, what i mean of course, is in a dark room.
    i am not a videophile at all though, i just decide on instinct.
  9. jermeri
    jermeri
    Jun 2, 2008
    2
    3
    Just got my w4000 last friday and trying to get the best settings. I mostly watch SD.
    I tried the hdtvtest settings on the movie mode but find it too dark when watching at daytime. Works with movies at night tho.
    If there are any football fans out there who got good settings for football I'd really like to try those out, SD viewing.
  10. richard plumb
    richard plumb
    Jan 27, 2002
    14,495
    Windsor
    +1,051
    how does the set handle settings? When I had a play in JL it seemed to have different settings per input. Is there a quick way to change between eg a daytime and evenign setting?
  11. naruto
    naruto
    Feb 25, 2008
    90
    Dublin
    +28
    Yes, you could adjust yr standard mode for daytime and cinema mode for night if you so wished.
    If you use the HDTV test settings but with the backlight at 2 I find it fine for during the day (even a sunny one like today)
  12. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
    Thank's i will try thoes and the HDTV Test settings. :)
  13. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
    Well i have not got my W4000 yet it's going to be delivered on wednesday. But normally like on my PX70 and the W2000 and other TV's the Cinema mode is too dark. But i don't know about the W4000 yet, the HDTV Test settings will probaly be the best they are the experts.
  14. zophiel
    zophiel
    Mar 18, 2008
    13
    3
    today i found that it looked a little off.
    so i upped the back light a bit and the contrast
  15. naruto
    naruto
    Feb 25, 2008
    90
    Dublin
    +28
    Have tried yr original setting for SDTV and there good but I found them a little dull/flat.
    They worked a treat removing the "blockiness" of the low-res Big Brother auditions material
    Will try yr adjustments tonight.
  16. zophiel
    zophiel
    Mar 18, 2008
    13
    3
    yea i cant get a happy medium at the moment. its cleared the picture and made it crisp but a bit grey/flat.
  17. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
    Well the TV has come. Im setting it up now. Has anyone else got any other settings i shall try?
  18. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
    When gaming on my PS3 and XBOX 360 the colours look a bit dunno what to describe it. Not as good as my PX70. Has anyone else noticed this?
  19. richard plumb
    richard plumb
    Jan 27, 2002
    14,495
    Windsor
    +1,051
    whats the best way to get going on this? I'm thinking especially setting black level, considering you have not just brightness/contrast but also the backlight setting.
    I'll have the dynamic contrast off, so I'd like as much native contrast as possible
  20. richdgrant
    richdgrant
    Apr 26, 2005
    375
    Edinburgh
    +10
    Could other 40W4000 owners post their settings for each input here please? I got mine last week and am having a tough time with the settings.
    I've looked at the HDTV Test settings but not sure if I'm happy with how it looks on some components.
    OK, so here's mine at the moment.
    HDMI 1 (SKYHD and Blu-Ray):
    Standard (for day viewing)
    Backlight 8
    Contrast 79
    Brightness 45
    Colour 53
    Colour Temp Warm 1
    Sharpness Min
    Noise Reduction Off
    MPEG NR Off
    Contrast Enhancer Off
    Colour Space Wide
    Live Colour Creation Off
    Cinema (for night viewing)
    All the same except Backlight Min
    Component (XBOX 360 for games and HD movies):
    Backlight 8
    Contrast 79
    Brightness 45
    Colour 53
    Colour Temp Warm 1
    Sharpness 10
    Noise Reduction Off
    MPEG NR Off
    Colour Space Wide
    I think SKYHD and Bly-Ray looks excellent in both standard and cinema mode. However, I'm not too keen on these settings for the XBOX 360 over component. As you can see, the only difference between the component and hdmi input is the sharpness (min cf. 10).
    So, 40W4000 and XBOX 360 owners, what are your settings?
    Cheers folks. :clap:
  21. richdgrant
    richdgrant
    Apr 26, 2005
    375
    Edinburgh
    +10
    Hey
    Anyone else willing to give out their settings for this tv?
    Please :)
  22. Hazard_Kaos
    Hazard_Kaos
    Feb 26, 2007
    147
    +3
    What is the TV like people? SD performance? Gaming?
  23. Usama
    Usama
    May 8, 2007
    6,477
    Manchester
    +386
    It's ok for SD. But it's awesome for HD, gaming on PS3 and XBOX 360 and Blu-Ray's. :smashin: ;)
  24. richard plumb
    richard plumb
    Jan 27, 2002
    14,495
    Windsor
    +1,051
    my current settings for SD. Seems generally ok for normal viewing. occasionally if its really sunny I'll bump the backlight a little, but its usually ok like this:
    "standard"
    backlight - 3
    contrast - 65
    brightness - 65
    colour - 53
    colour temperature - warm 1
    sharpness - 12 (this is off for HD, but I find its needed for SD as its too soft without a decent amount of sharpening)
    Noise reduction - low
    MPEG noise reduction - off
    Advanced contrast enhancer - off
    Colour space - standard
    also light sensor = off
    for HD its pretty similar
    "cinema"
    backlight - min
    contrast - 70
    brightness - 57
    colour - 57 (based on avia colour bars and blue filter)
    sharpness - min
    Noise reduction - off
    film mode = auto
  25. 123
    123
    What is the best settings for xbox360 ?
    Need to change settings for pc connection ?
  26. richdgrant
    richdgrant
    Apr 26, 2005
    375
    Edinburgh
    +10
    I too am interested in this... :)
  27. pio
    pio
    Jun 30, 2008
    9
    hi guys.
    i am now a proud owner of a 40w4000.
    i must say that ata first i wasn´t really happy with picture i as getting. but now after calibrations i am completly happy i have a superb picture.
    for freeview i just have the standard settings cause i almost don´t watch it.
    for blu ray and dvd´s i use the hdtvtes settings:
    picture mode: cinema
    backlight: min or 8 depending if it´s day or night
    contrast: 79
    brightness: 50
    colour: 53
    colour temp: warm 2
    sharpness: min
    noise: off
    mpeg: off
    Advanced settings:
    contrast enhancer: off
    colour space: standard
    Feature submenu:
    quick start: off
    power saving: standard
    light sensor: off
    film mode: auto
    for playing ps3 i use:
    picture mode: standard
    contrast: 79
    brightness: 50
    colour: 53
    colour temp: warm 2
    sharpness: min
    noise: off
    mpeg: off
    Advanced settings:
    colour space: wide
    live colour: medium or high
    Feature submenu:
    quick start: off
    light sensor: off
    film mode: auto
    note: sometimes i even watch blu ray with the ps3 setting´s, i think that the live colour really makes a difference and add so much more colour.
    question: by changing the colour space from standard to wide are we loosing better blacks or something? i don´t really understand much about tv´s, but i go to the ps3 and change rgb full do limite or full with colour space set to wide and i don´t see any difference.
    p.s: sory for my english
  28. pio
    pio
    Jun 30, 2008
    9
    what sound do you prefer, dolby virtual or bbe viva??
  29. Stoney
    Stoney
    May 20, 2008
    12
    Can anyone advise me, will the settings on my V3000 be pretty much the same as these?
  30. dibdab
    dibdab
    Apr 29, 2005
    1,374
    Kent
    +108
    Stoney there is a V3000 settings thread floating around here somewhere.
