Sony Bravia 32inch - Will this wall mount fit?
AV COM
AVForums Sponsor
Most 32" TVs use a 200x200 VESA mount (the 200 is the spacing between the mounting holes on the back of your TV in mm). It looks like the one linked to should hold anything up to 400x200, we stock a similar design. If in doubt measure the holes on the rear of the TV or ask the retailer, supplying your TV's model number.
Amnesia180
Thank you for the reply.
I notice you have free postage and the mount looks to be higher quality.
I do have a question though. The description states it holds all TVs from 33 - 60" (which is too large for my 32").
Then underneath it says fits all 23" - 37" (which will fit my TV). Can you confirm.
Does it come with all fixings for the wall, etc?
Sony A84L/A80L BRAVIA XR OLED TV Review - COMPARED to LG C3, Samsung QD-OLED & LG G3
Back
