sony bdp-s360 prob w/ hdmi out
paulped
hi,
i just bounght a bdp-s360
and i tried using the hdmi out
and all im seeing on my tv is just snow
the component and composite out is working fine
any help will be greatly appreciated
regards
and thanks in advance
paulped
i just wanted to add
when i turn on the blu ray, it shows the sony welcome screen before going all snow
and i know the cable and outlet on the tv works
i use to have an upscaling dvd player on it and working fine right before upgrading to the bluray player
skk3
Might be worth switching to another HDMI socket and running auto set once again...it seems that there is obviously a handshake issue, maybe at the TV end because it displays a signal and then goes snowy. If it was the player there would be no signal at all?
nwgarratt
It still could be the cable. 1080p especially when playing a blu ray uses a lot more data than even a uspcaling 1080p dvd player.
What happens if you choose 720p?
paulped
thanks for the replies
i noticed when i went to:
video settings
->output video format
the screen where you chose hdmi, component video, or video (composite)
i was only able to select component or video, the hdmi selection was not lit up and accesable
i have tried 3 different hdmi cables
are there different grades of hdmi and do i need a different one
thanks
atrainedmonkey
Hi, did you find a solution?
I just bought a s363 today, got it home and didn't even get a snowy screen on my 40" samsung b550. It could not find the signal and like you claimed, the bluray player couldn't be set to HDMI in the output settings.
The HDMI cable I have works for plugging my mac into the tv so I should think that is fine.
I have tried turning off any auto-detect features like deep colour in the bluray and have turned off Samsungs "any net" incase its a HDMI handshake issue.
As it stands Im going to take it back to John Lewis on Friday and try to get a replacement.
