knuckledusta72
anyone know if the firmware update for the sony BDP-S350 is available to download yet? and if so where from?
Anyone know what this update fixed?
Here you go.![]()
Have you tried powering the router off and on? I would have thought that would solve it for now.
Do you think sony will ever add any more features to this player or have they now moved onto a newer model and this one will pretty much be left as it is. I know I am being extremly hopefull here but can someone say 100% that DTS-MA decoding can not physically be added to this machine via a software update. Cheers.
Here you go.![]()
Unfortunately, that link takes you directly to a very old firmware update !
Taking the 'Firmware Download' link from here
Blu-ray Players BDP-S350 Sony Europe Customer Support Portal
should always take you to the latest version.
Or you could just network connect your player and select the appropriate options for it to look for the latest firmware itself !
