Sony Android TV, remote control issue
rxtarcher
Hello,
I have the "Sony KD-55XF9005" which comes with the "Sony RMF-TX310E" which only works with IR, except the button of the voice command wich works via Bluetooth.
I wanted a remote control which all of its buttons works via Bluetooth, so I bought the "Sony RMF-TX600E". When I manually connect it with the TV it works properly. The thing is that everytime I turn off the TV and turn it back on a few minutes later, the remote control isn't bluetooth paired with the TV so it doesn't work. I have to to go to Bluetooth settings and pair it again.
P.S.: I can turn on the TV because the remote control works with IR when it's not connected with Bluetooth.
Does anyone know how can it be automatically paired everytime I turn on the TV?
Thank you.
Omartahhan2
Hello every one
I need you help
I have a sony bravia tv with android os x800h
Somehow it's remote control exposed to a micro wave waves .. and it stopped working after that ... is it possible that it stopped due this reason?!
If so .. how can fix the issue
I tried resetting the remote many times .. but useless.. no IR
Oculus Quest 2 VR headset + Rotel A14 MkII Amp Reviews & Best of the Month
