sony amp
Discussion in 'AV Receivers & Amplifiers' started by luv ya jen, Jun 9, 2003.
Tags:
  1. luv ya jen
    luv ya jen
    sony strde475 £119.99 richer sounds trade in my sherwood 6103 amp get £60.00 therefore i get the amp for £60.squid. Now (A) IS THIS A GOOD PRICE (b) IS THIS A GOOD AMP RUNNING WITH A SONY DVDR
    THANKS GUYS
  2. hamtaro
    hamtaro
    :confused: how come you can 60 trade in on your sherwood?
  3. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Hamtaro - RS extended warranty has a 50% buy back guarantee if returned within three years.
    Luv Ya Jen - You probably will get an improvement over the Sherwood but can you afford to go to adding £120 'cos then you're into Yamaha 430 territory & the joys of DPL2. Don't forget that the RS thing is a buy back not a trade in so you can get your £60 & buy from whereever you want
  4. hamtaro
    hamtaro
    so sometimes extended warrentys do pay off?
  5. sounddog
    sounddog
    Dec 11, 2002
    3,416
    107
    Leicestershire, UK
    +474
    Are you sure about that wilber ... I'm sure the small print is that it's only on trade ins. Also when we bought our SR5200 about a year ago now ... the 50% trade in was only for 1st year with sliding scale after that.
    Vikki
  6. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    When I bought my 630 I took back my 2yr 11 month + a few days old Sony to Bristol RS & got £100 cash in my grubby paw (I then drove up the M5 to Cheltenham RS where they had stock and bought the receiver - Bristol having originally told me that they had stock)
    Maybe they've changed the terms on the new one - it used to be 50% if you have the box, manual , rc and the unit was unmarked.
  7. sounddog
    sounddog
    Dec 11, 2002
    3,416
    107
    Leicestershire, UK
    +474
    wilber ... think you're probably right that they've changed T&C.
    I bought a Sherwood amp about 4 years ago, then got 50% when traded it for a Sony 930 (about 9 months later), then got 50% back trading it in for the SR5200 (around a year ago) ... but the docs with the SR5200 said it was only 50% in first year ...
    Havn't bought anything since the SR5200 and got warranty so don't know if they've change it again.
    Vikki
  8. luv ya jen
    luv ya jen
    anyway back to the matter in hand IS THE AMP ANY GOOD
  9. hamtaro
    hamtaro
    for the price it looks ok, and its 80 watts per channel.
