Sony amp test tone
Discussion in 'AV Receivers & Amplifiers' started by Clarkey, Dec 21, 2003.
Tags:
  1. Clarkey
    Clarkey
    Dec 27, 2001
    141
    Manchester
    Hi, I have a Sony STR DB830 a/v reciever. When I use the test tone, I'm hearing a different tone from the fronts. Is the tone supposed to be different or is there something wrong? btw - the fronts im currently using are TDL Nucleus 2's, but using different cables for the L & R.
    Clarkey
  2. Clarkey
    Clarkey
    Dec 27, 2001
    141
    Manchester
    well I just swapped the speakers over and its still the same. So I can only assume that its either supposed to do that or the cable is responsible. Ill buy some new cable next time im in RS. Another thing is that the right channel is MUCH louder than the left at very low volume, this is the channel hooked up with thicker cable, Ill put that down to the lower resistance of the cable.
  3. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    Might have something to do with the location of the speakers,try puting them next to each other and trying the test tones again.I used to get this with my mission speakers ,idont notice it with the tannoy's i have now.
  4. Clarkey
    Clarkey
    Dec 27, 2001
    141
    Manchester
    will do, ill report back when ive got round to it :)
  5. Clarkey
    Clarkey
    Dec 27, 2001
    141
    Manchester
    tried that and it still sounds different, allbeit less difference than before.
  6. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
    I have a Sony [different model] and the sweep is a uniform tone through all speakers.
  7. Clarkey
    Clarkey
    Dec 27, 2001
    141
    Manchester
    hmm, might take these speakers back anyway, im not sure about them. Id rather have the Mission's but they were out of stock and i wasnt coming home empty handed. Also with the missions I can get the matching centre.
    Thanks for the info
