sony amp protection flashing
Discussion in 'Home Cinema Speakers' started by richie44, Apr 13, 2002.
  1. richie44
    richie44
    Just took delivery of a Sony str870DB amp last wednesday which i wired up the fs2-av's to,every thing working great till the morning (sunday) i was watching tv at a low volume when the rear right speaker made a short popping sound and the amp went into 'protection mode'........i checked the speakers with another amp and they seem not to be affected.i turned amp off from the mains for a few hours to see if this would reset it but its still the same.....any ideas????????
  2. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    "protection mode" is usually a wiring fault...
    double check your connections at both the amp and sub ends...
    must be something loose.. (amp end?)
    if no joy, unplug the speakers one by one from the amp end,
    till you get the Sony live again - you should find the problem (assuming its not hardware). reconnect the speakers back in one by one, doing a test tone at each stage. if it fails again, you've found the bad connection.
  3. richie44
    richie44
    ive disconected all the cables from the amp and its still the same
  4. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    hmmm...not sure then... could be a fault on the amp maybe.
    are you its the overload message you are getting, and not the "protect" message from something plugged in digitally (copy protection one)?
    try switching the source to something analog just in case.
    failing that, unplug any/ all digital sources (dvd, minidisc etc) to see if it makes a change.
  5. richie44
    richie44
    ive unpluged every thing from the back and its still does it,the words 'protector'flashes
  6. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    so absolutely no speaker cables or digital sources plugged in then... and amp switch to something simple like CD or TV.
    does sound like speaker/ overload circuit kicking in... it thinks there is a problem somewhere.
    could be something has gone in the amp unfortunately. :(
    any way to reset the amp... sure my old Sony had something similar?
  7. Mike Dando
    Mike Dando
    I had this message on my 930. It was caused by speaker connections touching. Rewired the connections and has been fine since.
  8. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    agreed, Mike. had the same thing with my old Sony 925.. but Richie44 doesnt (or did) have no speaker cable plugged in with the error still coming up.
    any joy since Richie?
  9. richie44
    richie44
    I phoned SONY and they told me its U/S.......I have sent it back to dealer and replaced it with a denon 2802..Thanks for all your remarks
