Limited info about general performance. I updated and don't see anything differentAny idea what it does?
HDR brightness level will always be maxed outHDR brightness levels.
I've only noticed recently that this setting is not saved "per input" like the other settings are.
Seems to be a one setting for all
Is this right, not sure if it was like this before or it's the fact that I'm watching more HDR content and only just noticed.
It's not maxed out. It's just at the same level regardless of what input I'm using.HDR brightness level will always be maxed out
If it’s not maxed out it’s not HDRIt's not maxed out. It's just at the same level regardless of what input I'm using.
If I set it at 25 for the iPlayer app it'll be at 25 on hdmi 3 where my media player is.
Some inputs like my media player need it almost maxed out. But the likes of iPlayer uhd HDR programs are uncomfortably bright.
Shame you can't set it how you want it per input like you can with all the other settings.
Bit of an oversight in my opinion
If the content is in HDR it automatically triggers a HDR preset on the tv which puts brightness at max ,nothing strange about the statement at all ,yes you can lower the brightness if you like ,but it’s put at max for a reasonThat's a strange statement.
The makers of the content do not know the capabilities of your TV or the lighting conditions of the room you are viewing it in.
Hence the ability to be able to change the brightness levels.
I'm just saying that it's strange that you cannot set it "per input"
When you set the tv up did you set it as wall mounted or table top ?Hi all, I've just bought an A80j77 and it's picture is outstanding, but one thing I've noticed is an issue with sound. On the whole the sound is great, but I've noticed certain frequencies seem to make it vibrate a lot. As an example anything with pianos or simply skipping through the menus seems to omit a vibration type sound. Has anyone come across any issues like this with this TV? I've tried all sound options including the EQ but nothing seems to eliminate the vibration if the right frequency is hit. Watching the news earlier and the reader had tone that could cause it to happen. The unit seems tight as a nut everywhere and it's wall mount is solid with nothing lose etc. The actual sound seems to come directly from the rear. Long winded and thanks in advance if anyone knows of any issues.
Wall mountedWhen you set the tv up did you set it as wall mounted or table top ?
Have you watched the likes of green planet on iPlayer in HDR. I find it painfully bright at max, along with most of the content on iPlayer.If the content is in HDR it automatically triggers a HDR preset on the tv which puts brightness at max ,nothing strange about the statement at all ,yes you can lower the brightness if you like ,but it’s put at max for a reason
Yes i,ve watched loads of HDR/DV content ,I haven't found any to be painfully bright tbh , what picture preset are you using?Have you watched the likes of green planet on iPlayer in HDR. I find it painfully bright at max, along with most of the content on iPlayer.
There's no reason not to want to turn it down.
I just find it wierd that you cannot set the brightness per input to automatically set for you.
Like I said big oversight
Custom preset.Yes i,ve watched loads of HDR/DV content ,I haven't found any to be painfully bright tbh , what picture preset are you using?
The tv maxing out the brightness with HDR content is exactly what it should be doing ,as its meant to be viewed that way , so its not really an oversight on Sony's behalf , in fact I,m not sure that ANY manufacturer allows you to do what you want .
Don’t have this and I’ve not heard it mentioned here. If you give an example of a source (named movie and audio track, or Netflix show) and volume level that introduces vibration I will try to reproduce. I do tend to use a soundbar for most films though.Hi all, I've just bought an A80j77 and it's picture is outstanding, but one thing I've noticed is an issue with sound. On the whole the sound is great, but I've noticed certain frequencies seem to make it vibrate a lot. As an example anything with pianos or simply skipping through the menus seems to omit a vibration type sound. Has anyone come across any issues like this with this TV? I've tried all sound options including the EQ but nothing seems to eliminate the vibration if the right frequency is hit. Watching the news earlier and the reader had tone that could cause it to happen. The unit seems tight as a nut everywhere and it's wall mount is solid with nothing lose etc. The actual sound seems to come directly from the rear. Long winded and thanks in advance if anyone knows of any issues.
