hackthegibson
Yes that’s correct.Afternoon All,
Is it still the case that this TV only supports 4k at 60hz via HDMI slot 2 & 3?
Andy
Andy
just noticed my SONY HT-ST5000 is showing “atmos” too. Bizarre that none of the Prime programs say “atmos” they still show 5.1?Yes Amazon Prime Video provides ATMOS, it worked on two firmwares prior to this latest one, see my post a page or two back. Not much content on there but Jack Ryan is in ATMOS. As mentioned previously the TIDAL music app also passes ATMOS content.
Sony A1E OLED Owners and Discussion Thread
Nor Realy, burn in, we rarely pause the screen or leave on the Sky Menu. We first noticed this on football, etc.www.avforums.com
Tried Disney+ and YouTube and these don't provide ATMOS.
Yes that's what I did, updated over the air then downloaded latest Android 9 firmwareThanks id done a update friday but its not the latest. The tv says software up to date so ill have to down load to usb
Well blow me, with this latest update, Jack Ryan has now lost ATMOS, but has reintroduced Dolby Vision!! .. what the heck is going on!?Yes Amazon Prime Video provides ATMOS, it worked on two firmwares prior to this latest one, see my post a page or two back. Not much content on there but Jack Ryan is in ATMOS. As mentioned previously the TIDAL music app also passes ATMOS content.
I know Dolby Vision was on series 1 but they seemed to have dropped after that.Well blow me, with this latest update, Jack Ryan has now lost ATMOS, but has reintroduced Dolby Vision!! .. what the heck is going on!?
Yes I knew S2 didn't have DV, but with S1, it originally had DV for me, then earlier this year S1 had dropped DV for just HDR10 but gained ATMOS. Now with latest firmware S1 has dropped ATMOS, but reinstated DV.I know Dolby Vision was on series 1 but they seemed to have dropped after that.
I believe over the air updates are staggered, so not available all at the same time. Have you downloaded the update to your USB stick from your computer, unpacked the zip and placed in the root directory?Hi all,
I need some help please.
My TV does not show an over the air update - still showing ‘latest software’ when I hit the search for update function.
I can’t seem to update via USB either, the TV does not start to auto-update instead it recognises the USB and shows me this screen, any ideas?View attachment 1410009
Yep,get the following screenCan someone who has the A1 and is connected to the internet and is in the UK try freeview channel 271 for me.
Please elaborate. Also note that lots of games don't have HDR implemented very well, or some games don't have HDR at all, but the PS5 tries to convert all games to HDR (which is bad IMO). If you think certain games are looking bad in HDR, try disabling HDR in PS5 system settings becasue genuinely a lot of games are supposed to be played in SDR, or even if they have HDR implementation it is poor and looks better in SDR.Hello. Does anyone have a PS5? I'm having a lot of problems with the Sony A1 and HDR in games.
Thanks for your quick reply! My problem is not related to SDR games at all. The thing is, if I set TV Black Level to Automatic and on Auto on the PS5 as well, all HDR games look very dark (A crazy example is Ghost of Tsushima which results in being unplayable like that. Even playing it on SDR is weird, the colour look faulty and washed out). The only solution I found is setting the TV Black Level on Full and Auto/Full on PS5. Then the picture on games like GoT, FFVII Remake and TLOUPartII look OK, displaying all grey gradations and I am able to see every detail also in darker scenes. I don't know if it is not correct to do so, but everything else provide a very dark HDR picture. The only problem with the FULL range RGB is that Ubisoft games in HDR still look very off in terms of colours and brightness.Please elaborate. Also note that lots of games don't have HDR implemented very well, or some games don't have HDR at all, but the PS5 tries to convert all games to HDR (which is bad IMO). If you think certain games are looking bad in HDR, try disabling HDR in PS5 system settings becasue genuinely a lot of games are supposed to be played in SDR, or even if they have HDR implementation it is poor and looks better in SDR.
I assume that on your TVs HDMI input you have set Game mode? Disable HDR on the console and then customise your Game mode SDR 'version' to your preferred setting. Now on the PS5, re-enable HDR to automatic and this will trigger the TV to enter Game mode 'HDR' version. Now do the HDR calibration sliders correctly in the PS5 video output settings. Also set your RGB range to Full but leave the HDMI black level to Auto on the TV (the TV on Auto will correctly match the Limited or Full setting on the PS5).Thanks for your quick reply! My problem is not related to SDR games at all. The thing is, if I set TV Black Level to Automatic and on Auto on the PS5 as well, all HDR games look very dark (A crazy example is Ghost of Tsushima which results in being unplayable like that. Even playing it on SDR is weird, the colour look faulty and washed out). The only solution I found is setting the TV Black Level on Full and Auto/Full on PS5. Then the picture on games like GoT, FFVII Remake and TLOUPartII look OK, displaying all grey gradations and I am able to see every detail also in darker scenes. I don't know if it is not correct to do so, but everything else provide a very dark HDR picture. The only problem with the FULL range RGB is that Ubisoft games in HDR still look very off in terms of colours and brightness.
Isn't that so, that games in HDR should not have their HDR settings changed by default because their default values, usually 50/50 brightness, should guarantee a proper HDR picture?I assume that on your TVs HDMI input you have set Game mode? Disable HDR on the console and then customise your Game mode SDR 'version' to your preferred setting. Now on the PS5, re-enable HDR to automatic and this will trigger the TV to enter Game mode 'HDR' version. Now do the HDR calibration sliders correctly in the PS5 video output settings. Also set your RGB range to Full but leave the HDMI black level to Auto on the TV (the TV on Auto will correctly match the Limited or Full setting on the PS5).
Load up your game in HDR mode. Check to see if there any further in game HDR calibrations you can do and optimise those. Play the game for 10 mins. Now quit game and disable HDR in PS5 system settings and load the same game up and play it for 10 mins in HDR. Whichever way looks the best to you, carry on playing the game in that way.
I hope this helps.
