Alex119
Established Member
Is there a regional rollout schedule? Or is it pot luck? I had the update direct through the TV on the 28th March.How long is it normally before updates go free to air?
So did I, came through on the TV before I saw it on here in fact.Is there a regional rollout schedule? Or is it pot luck? I had the update direct through the TV on the 28th March.
you're welcome!Btw, after the factor reset, after setting
Thanks mate - all useful info - still tinkering but unfortunately the volume control is effectively useless when using TV is through an AVR. You can still increment up and down 1 notch via CEC but can not set specific numbers.
Can't recommend a Harmony Elite enough - you won't be disappointed. I remember it seemed stonkingly expensive at the time (several years ago now) but have 0 regrets; one of the best pieces of tech I ever bought. And you soon get over the treating it like it's made of china phase
The soundbar shouldn't stop the Sony DV passing through, my Yamaha amp has no bother.That's good to know as I have the Oppo 203. I also have the Oppo routed through a Yamaha 2700 soundbar which has 4k pass through and a month or so ago had a f/w update to allow it to pass through DV. Does anyone know whether the DV pass through will work for the low latency Sony DV version? I am close to having the TV delivering DV and the Oppo via HDMI but will I be scuppered by the Soundbar not being able to pass through from the Oppo and requiring another f/w update before it does so??
I'm in London.Are you in the same area at all? Im s.east kent, nothing yet...
No the Sony Oled has loads of problems and Oppo have been flooded with calls.What do you mean? for DV support? Oppo will be releasing a DV update to support the Sony DV.
My HDR is working fine and my nephew who also own the Sony Oled and oppo 203 his is working fine to.
I wonder how yours got it ota....I'm in London.
I have had an OPPO since I had the A1 and have not had one problem. Has been a great pairing.No the Sony Oled has loads of problems and Oppo have been flooded with calls.
I have done quite a bit of testing and I am going to stick with Expert 1 for now I think until some concrete info comes out. I can see what people are saying but I see a similar behaviour switching between expert 1 and neutral even on non DV sources so I’ll put it down to being the best way to have it for now. Neutral is just too cold and blue tinted for me personally.Samv0808 passed on that in AVSForums some Pro calibrators were recommending Expert 1. This is also what it defaults to if you click "Reset". Some are saying though it might be a bit too yellow. I'm going to stick with Expert 1 for now.
what problems?No the Sony Oled has loads of problems and Oppo have been flooded with calls.
Apparently, there's "no difference" with HDR on the Oppo. Difference with what, who knows?what problems?
Dolby Vision is great. The colors are much more saturated and cinematic than in HDR! Re-watched parts of Stranger Things immediately after updating, sublime!Good to know. Half way there then. And DV. Not bad
Mh, I'll give it a try.Just curious if anyone has tried “Color temperature” Warm. It’s in between Neutral and Expert 1. I find it to be a happy medium between too blue and too yellow.
Dan
Not to me. I would if I hadn’t already. I have the steel book on order but I won’t be watching till the OPPO is updated.Dolby Vision is great. The colors are much more saturated and cinematic than in HDR! Re-watched parts of Stranger Things immediately after updating, sublime!
I wonder if I should buy the Oppo 203 soon or wait for the new Pana UB820?watching it till the OPPO update.
On the other hand there are very few discs available but I’d like to watch the new Star Wars movie in DV. Am I crazy if I buy the Oppo just for that movie ?
Is there any Dolby Vision disc in the UK region that anyone can recommend as most just state Dolby Atmos and just HDR.
Following the USB update Netflix presented a blank screen despite stuff like Amazon appearing to work. A Settings menu restart which looks like a hard-reboot as you can see Android starting restored Netflix.
OMG! DolbyVision enabled Netflix full 4k video looks fabulous and let's face it the TV's image performance wasn't exactly shabby before. Very impressed, blown away in fact.
So how does it compare to hardware enables DV like that on LG TVs?
Does the Sony light DV do the job? Certainly looks great.
Gents, I have a question: if you wall mount the A1, how big is the typical gap from screen to wall (assuming a standard slim mount is used). Also, is it relatively easy to do? I have seen a few comments that the rear subwoofer stand causes issues. I’m torn between buying an A1 now for abt £3,000 or waiting for the A8F when it releases in the UK. I know it will likely be more ££s, but from what I have seen it should be a more standard mounting setup.
I’m delighted to see the DV update seems to be generally well received by you all, it’s what I’ve been waiting on before biting the bullet.
