Sony A- fit Lenses to rekindle my interest.
Discussion in 'Photography Forums' started by Doctor27, Jul 20, 2015.
  1. Doctor27
    Doctor27
    Apr 5, 2008
    242
    28
    +33
    Hello all,
    I want to get back into photography, as I have really lapsed over the last 18 months plus. Finding the woman of your dreams and having a baby can do that!
    I used to be, if not a prolific then consistent amateur and have taken hundredss of photos and have a hard drive full of folders.
    As I have had a tendancy to be indiscriminate about what I shoot and the technicalities of photography have often bamboozled me, I want to hang on to my current kit, but expand so I can grow a bit more in confidence.
    I have a Sony A330 with kit lens and two zoom lenses. I was thinking of a wide angle lens, and have seen an 11-18mm Sony and its Sigma equivalent. There is also a more expensive Sigma which I assume is due the f/stop difference. I do like landscape photography and think the f/stop range would help me in low light(?).
    Would any of these lenses benefit me?
  2. snerkler
    snerkler
    Jun 18, 2011
    21,404
    +12,153
    Without knowing what other lenses you have, and what your budget is it's difficult to offer further advice. I don't find the speed of a lens particularly important for landscapes tbh as you tend to shoot at f8 or higher for your traditional landscape shots and use a tripod, especially when light is low to help keep ISO down when using small apertures. The only time I can see the need for wide aperture landscape lenses is for arty shots, or interior handheld shots. That being said a number of f2.8 wide angle lenses fall into the 'pro' category and as such often have better optics, better build etc.
  3. Faldrax
    Faldrax
    Jun 5, 2009
    1,128
    113
    Chandlers Ford
    +535
    With a wide angle lens you can happily shoot at much larger apertures, unless you need something close to be in focus, as DOF is so large (EG on FF 24mm f/2.8, subject at 10m, near focus = 4.05m, DOF infinite!).
    A lot of the time you will stop down anyway for landscape, as you actually want a longer shutter speed, but there are occasions when a shorter speed is useful (EG in twilight, as you suggested).
    Personally, before buying any Sony fir lens I like to check the Dyxum lens database
    Alpha A-mount and E-mount lenses guide
    as this gives an indication of how other user view the lens - remember these are written by people who have bought the lens, so have a certain element of bias, but it does allow comparison of similar lenses.
    The three you list all have similar totals, so there's not a great deal between them, but reading individual reviews may indicate particular strengths or weaknesses.
    • Thanks Thanks x 1
    • Agree Agree x 1
    • List
  4. Doctor27
    Doctor27
    Apr 5, 2008
    242
    28
    +33
    Thanks for the replies guys.
    My other lenses are a Sony 50mm prime, Sony 75-300mm & Tamron 55-200mm. I have a budget of £250 but could stretch it a bit.
  5. salparadise
    salparadise
    Jul 24, 2010
    530
    +63
    I hope you don't mind me tagging a similar question into your thread Doctor27 but it will save me starting a fresh one?
    I am looking for a suitable lens for capturing some photographs of wildlife with an emphasis on birds.
    I don't have a large budget and definitely consider myself a complete novice so if anyone knows of a lens suitable for a beginner in both skill and budget for a Sony A580 I would appreciate it? Thanks and apologies for the thread hijack!
  6. snerkler
    snerkler
    Jun 18, 2011
    21,404
    +12,153
    What do you class as a large budget? The 55-300mm can be had very cheap and can produce some good images. AF can hunt a bit, but for the price if perfectly acceptable. The next obvious choice would be the 70-300G but that's more expensive. Ideally for birding you could do with more reach though so the Sigma 150-500mm might be a better bet, and then of course there's the Tamron and Sigma 150-600mm's but you're going up in price again.
    These were taken with the 55-300mm, although it was right at the start of my photography so not the best examples,..... by a long way :blush:
    [​IMG]DSC08181 by TDG-77, on Flickr
    [​IMG]DSC09019 by TDG-77, on Flickr
    [​IMG]DSC09101 by TDG-77, on Flickr
    And some non bird shots taken with the 55-300mm
    [​IMG]DSC03830 by TDG-77, on Flickr
    [​IMG]DSC03924 by TDG-77, on Flickr
    [​IMG]DSC03289-2 by TDG-77, on Flickr
    [​IMG]DSC03321-4 by TDG-77, on Flickr
  7. salparadise
    salparadise
    Jul 24, 2010
    530
    +63
    having had a quick look over the lenses to mention I quite like the sound of the sigma 150-500 albeit at more cost than I initially wanted to spend. I will spend some time looking at the other lenses and see whether one of the cheaper lenses is a better bet at this stage. Many thanks for the reply and for showing what the 55-300 is capable of.
  8. shotokan101
    shotokan101
    Jun 16, 2009
    75,869
    33
    Glasgow
    +25,826
    Also have a look at the Sigma 100-300mm F4 and possibly adding a 1.4x Teleconverter for additional reach
