Sony 940 to Mission 7AS2 Sub
Discussion in 'AV Receivers & Amplifiers' started by laurianlee, Jul 13, 2001.
Tags:
  1. laurianlee
    laurianlee
    Greetings
    Currently new to the HC scene and have got on okay so far with the connections.....but the 940 to sub has thrown me. At the moment I have them connected between the 940 sub-woofer pre-out and the 7AS2 line in (L & R) via a twin RCA phono. This does not utilise the 7AS2 LFE input which I understand is the best to use....?? The 7AS2 LFE input is a single RCA type but where does the output come from on the 940??
    Hope someone out there can help with my first enquiry on this rather useful bulletin board??
  2. riddler
    riddler
    The subwoofer outs on the sony are not a left/right pair, its just a pair of lfe outputs.
    They output exactly the same signal.
    Just connect one of them to the LFE input on your sub.
    Sony have done this so it is easy to have a pair of lfe subs.
