Sony 940 sound
Discussion in 'AV Receivers & Amplifiers' started by Zack, Mar 30, 2001.
Tags:
  1. Zack
    Zack
    Hi can anyone help
    I have sony 940 +tosh Sd100e dvd and the sky pace digi box and mission fs2.
    my problem is when i have the amp on the dvd sound setting or any other i can hear the sky
    channel coming out of my speakers .
    I only have sky connected to the amp with £10 phono leads .thanks
  2. Monster
    Monster
    Oct 9, 2000
    978
    Adelaide
    +30
    I also have a similar problem in that I can hear the sound from my tuner. (I use a seperate Denon tuner because it seems to pick up the signal better than the integrated) However, as soon as an input from DVD TV etc enters the amp the tuner signal cannot be heard, even with the volume up loud and a silent part of a film. I therefore do not look at it as a problem. I don't get any hiss and am very pleased with the amp.
  3. Zack
    Zack
    Yeah it is ok when ilisten to a dvd
    and i have no hiss as well
    great amp
