Sony 940 - Protector
Discussion in 'AV Receivers & Amplifiers' started by jmlane, Feb 25, 2001.
Tags:
  1. jmlane
    jmlane
    In the last week the protector has been coming on whilst watching films - most anoyingly when I was about to show off how amazing a particular explosion was. Anyway my rears are currently connected with electrical cable because I'm a very poor student with very expensive hobbies - could the this be the cause or is there a problem with my relatively new amp.
    The amps black if that helps at all.
    Thanks.
    [This message has been edited by jmlane (edited 25-02-2001).]
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    So what's the problem? Should we guess?
    Perhaps it helps if you paint it pink with yellow dots ... [​IMG]
    [This message has been edited by Reiner (edited 25-02-2001).]
  3. jmlane
    jmlane
    I've said what the problem is the protector of my Sony 940 amp has been coming on during parts which are a bit loud (eg. explosions etc).
    So you think painting might make a difference, are the colours you've suggested the most likely to solve my problem or there others which will have more effect?
    Thanks.
  4. jonny
    jonny
    Aug 14, 2000
    279
    Hertfordshire
    +3
    JMLANE, All i have to say is: ARE YOU BEING SERIOUS?
  5. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Sorry, I understood you were watching a film called "Protector", but you mean 'protection circuit'!
    And you amp is not black in color then I assume!?
    Then there are two possibilities (and this time I am serious):
    Check the wiring of the LS cables, there might be some strands causing a shortcut.
    Else you are driving the amp too hard, what's the impedance (and type/model) of your speakers?
    Are you using a subwoofer? Active/Passive?
    Rgds,
    Reiner (who's English is obviously pretty bad)
    [This message has been edited by Reiner (edited 26-02-2001).]
  6. Mike Dando
    Mike Dando
    The same thing happened on my 930 after about
    a year. Without doubt the problem was caused by dodgy speaker connections.
    As it happened I was about to replace my cabling anyway. New cable, no more PROTECTOR problems.
    Mike.
  7. jmlane
    jmlane
    Thanks, I'm going to get some decent cable (QED Micro) for the surrounds later in the week.
    My amp is black and it's staying that way as I was just joking (Jonny - I don't think anybody (well not many people) could be that stupid!)
    Also reiner your English is better than mine and I do English A-Level!
    [This message has been edited by jmlane (edited 26-02-2001).]
