Sony 925 going wrong
Discussion in 'AV Receivers & Amplifiers' started by Fartpants, May 15, 2001.
Tags:
  1. Fartpants
    Fartpants
    Now and again I turn it on and no sound, registers a DD or DTS signal is getting in, but no sound from the speakers, no hum buzz or anything. Try again half an hour later and sound ok.
    Can anyone give me any pointers?
    Regards
    The flatulent one
  2. Guest
    Nothing of any real to you, but that particular Sony was, unfortunately riddled with bug's and nasties. I don't believe you would have to search very hard (usual search-engines) hard to discover a mass of imformation on this model's "quirk's".
    Regards
    SteveEX
